CIVIL 3D SURFACE CREATION BUG
Dear Civil 3D users,
I have truble with sufrace creation for a short longitudinal problem that I am currently working on.
I have imported points, create an alignment from the same and up to there everything is okay.
When I create the surface and define it by adding points, the surface appears to jump at some point...and get to some other points a few meters away.
This results in a profile that has gaps...kindly find attached a simplified version of my problem.
Please help me find how to solve this
Fabrice
Replies (11)
Mike.M.Carlson
Hi-
Can you share a picture or attach your dwg, so we can understand your problem better?
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
AllenJessup
In Surface Properties, on the Definition tab, expand Build and Change "Use Maximum triangle length" to yes and enter a "Maximum triangle length" of something appropriate like 100m. Also for a longitudinal surface. You'll bet better results if you create a Featureline along the alignment using the point elevations and offset that a small amount left and right. Use those Featurelines as breaklines.
You can also Create a Profile from a point file.
Allen Jessup
CAD Manager - Designer
Jeew-m
Dear Friend,
It seems like for some reason some points are not taken to create the surface.
I see that you have your points in an increment order.
So you can follow this method.
Connect the points using a 3d polyline.
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Then project it to your profile view.
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2017/...
If you need to convert it to a profile you can use this.
https://www.youtube.com/watch?v=-VE957b29C4&t=1s
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
BushW
Hello @Anonymous
Do you think its possible to post a drawing or image so, we can better understand the issue. Thanks
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Hello Mike,
Attached is the dwg document I am working on.
In advance, thanks
Fabrice
Dear @AllenJessup
Many thanks for your message.
i have done what you proposed and its working partially, only one part of the problem was solved but the same problems remains at three different locations
Pleased find attached a dwg file.
Hoping to read from you soon,
Fabrice
AllenJessup
Did you create parallel Featurelines? You'll never get a Surface made from one line. Create a Featureline along the alignment using points for grade, Offset the Featureline 0.5m on either side, create a Surface from those Featurelines.
Allen Jessup
BushW
Hello @Anonymous
I'm just checking in to see if you need more help and did the suggestion that @AllenJessup provided work for you?
If so, please hit the ‘Accept as Solution’ button so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Dear @BushWBushW, and @AllenJessup
Many thanks for your email, I did not make it to create the feature lines. So, I decided to create points which are close to where I had the jumps. These points have different coordinates(but not very far from the known ones) but same levels as their closest points. i assumed this would help the software make a reasonable interpolation and it worked.
Best regards,
Fabrice
Dear @BushW,
I have a question on a different subject: how do I place types of pipes and different fittings such as valves, bends tees on my network? and Does civil 3D 2015 has all material catalogs?
Thanks in advance,
Best regards,
Fabrice
BushW
Hello @Anonymous
Can you please post this question as another post since its a different matter and subject? You'll have a better chance of getting your question answered not only from me but, also from the community.
Wendell
Wendell Bush
