Civil 3D Forum
civil 3d sample sections band text alignment
6 REPLIES 6
429 Views, 6 Replies
hello,
when creating a sample section profile my band text isn't aligning with the band boarder?
attached screen shot below.
6 REPLIES 6
Dexterel
It seems to me you have 4 bands, 3 for making the band boxes and 1 for making labels. Is this correct?
You definitely need to modify the band labels to show in the desired location.
I don't know how your band labels anchor point, attachment point and x offset are.
Upload your DWG and I will try to explain what you need to do.
Hi
Depending on the style you are using in the bands.. ( i think you are using 1 label style for the 3 values in one band and 2 empty bands just like (
Civil 3D Country Kits for United Kingdom & Ireland )
 In this case you just modify the label at  label style composer and just add some extra ( space ) between the 3 values ...
Dexterel
How is this different from what I said?
What nerve to repeat what I said and get credit.
in reply to: Dexterel
That right .. you get the first half of the answer
but the difference comes with the space between the labels not the attachment or the X or Y offset .
both has help me a lot, thank you gents
Dexterel
I really don't want to drag if further. But I said:
"You definitely need to modify the band labels to show in the desired location"
You just completed whit "by adding spaces".
The thing whit anchor and offset was if he had multiple components in label.
Anyway have a good day.
Rail Community
