Civil 3D Profile View Scale Not Accurate
engineeringNLTNM
Message 1 of 15
engineeringNLTNM
Hi everyone,
I am doing a job which I braught a Topo survey into Civil 3D and made it a TIN. I already changed from feet and inches to metres in the settings. However, when making a profile view of a road, the scale of the profile is not accurate. The figure showing 1.5240 show be showing 5 to match. Can anyone help out as I am new to the software.
Replies (14)
Message 2 of 15
VincentSheehan
Check the profile view settings. It looks like the profile view is in feet and the dimension (1.524) is in meters.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 15
engineeringNLTNM
Hi Vincent,
I cannot find where to look in the profile view to determine if it is in feet or not.
Message 4 of 15
engineeringNLTNM
Hi Vincent,
I noticed my intervals are in feet while everything else is in metres.
However, I cannot find a way to change this back to metres.
We only use metres and mm in Ireland
Message 5 of 15
doni49
The profile view STYLE controls what the Profile View looks like and that includes the spacing between the grid lines.
I think you'd be better off using a template that is intended for metric and then importing your survey and creating your profile.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 6 of 15
engineeringNLTNM
I agree too,
However, I am the only person in my company using civil 3d.
Is there a template online which I could download or would I have to get onto another company to share.
Thanks for your reply
Message 7 of 15
doni49
The grid spacing is found on the Horizontal Axes & Vertical Axes tabs of the Profile View Style dialog box.
Don Ireland
Message 8 of 15
engineeringNLTNM
As you cans see in attached screenshot, my intervals are in feet while everything else isnit, unlike yours.
Message 9 of 15
doni49
Your C3D installation should have come with Imperial and Metric templates installed by default.  I don't know for sure where the default is and because my company doesn't use the OOTB templates (we have custom ones), I don't have them installed and can't look up their location.
Do a search for *.dwt.  That's the extension used for Acad templates.
Don Ireland
Message 10 of 15
doni49
I realized my file is different.  It appeared that you wanted to know where to set the spacing for the grid lines.  That's all I was trying to show you.
Don Ireland
Message 11 of 15
engineeringNLTNM
Yes I understand, isint it strange that they mix feet and metres for profile settings. You would think it would all be the same. Would you know how to change the interval units from inches to metres as this is whats catching me I have realised? I am also looking for the metric template as you suggested.
Message 12 of 15
doni49
I agree too,
I was able to find this file.  It's what autodesk provides for learning to work with Corridors.  But it's in metric -- just save it as a template.
Don Ireland
Message 13 of 15
doni49
I just took another look at your screenshot and see what you're talking about now.  I'm not sure where that particular setting is.  The fact that there are little settings all over the place that would need to be updated is the reason I suggested starting over with a metric template.  Hopefully the file I provided above will help you with that (just delete everything out of it before saving it as a template).
Don Ireland
Message 14 of 15
engineeringNLTNM
Thank you very much you have been very helpful, AutoCAD is so much easier 😛
Message 15 of 15
doni49
Happy to help.  Did that get you what you needed?
Edit:  Never mind.  I hadn't gone back to the message list yet.  When I did so, I saw that you had marked it as solved.  So now I know the answer to my question.
Don Ireland
