Civil 3D Forum
Civil 3D - Profile View, 2nd Y Axis with different scale?
3 REPLIES 3
jim.poole
599 Views, 3 Replies
I'm trying to produce a profile from a drawing with 2 axis' with different scales (using Civil 3D 2018)
I have a profile for a topographical surface, which is measured in metres.
I have a series of profiles for settlement curves, which are measured in mm.
I'd like to plot them all on one profile view, with the topo surface references on Axis Y1, and the settlement curves referenced to Axis Y2.
Currently I have 2 profile views on top of each other with a different vertical exaggeration, which works with a bit of tweaking to the bands and various layers displayed, but means modifications to both to manipulate.
Anyone ever managed this - I don't think it's possible... over to you!?
3 REPLIES 3
tcorey
in reply to: jim.poole
Here's a short LISP that will divide all your elevations by 1000. That will effectively convert from mm to m.
(defun c:go ( / pro pvis cnt ctr pvi )
(vl-load-com)
(setq pro (vlax-ename->vla-object (car (entsel "\nSelect Profile to convert: ")))
	  pvis (vlax-get pro 'PVIs)
	  cnt (vlax-get pvis 'Count)
	  ctr 0)
(while (< ctr cnt)
		(setq pvi (vlax-invoke pvis 'Item ctr))
		(vlax-put pvi 'Elevation (* (vlax-get pvi 'Elevation) 0.001))
		(setq ctr (1+ ctr))
(princ)
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
CADvisers
I may not be completely understanding, but can you use "Create superimposed profile" to show both profiles on one profile view?
You could apply a "raise/lower" edit to your surface (that's in meters) to match in mm.  Then superimpose the mm profiles onto the profile view showing the surface profile view.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
lynn_zhang
Hello @jim.poole ,
Just checking to see if your problem has been solved. Have you tried the suggestions from above and did they work for you? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
