Civil 3d problems in earthworks modelling
Message 1 of 10
I'm having some problems with Civil 3d recently.
I use the software to create earthworks formation sufaces, so is Civil 3d the best software I should be using for this or is there something different to use.
Currently I create the feature lines with my levels and add these to the formation surface, I use the grading tool to grade back to existing ground surface.
This is the area where the problems occur, Civil 3d crashs often especially when there is grading in the file. On many occasions I have lost files as they become unusable as the file will crash if I modify a point in the surface or if I change a feature line level.
Are others having problem?
Are others doing similar earthworks surface but use a different process or in fact a different software?
Any help on this would be a great
Caroline
Replies (9)
Message 2 of 10
civilman1957
Good morning,
What version? What service packs are installed?
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 3 of 10
tmachado
Hi @Anonymous, when working with featurelines and grading objects you need to check the drawing for error running an AUDIT often especially if you delete/edit the grading objects often.
To me, it sounds like your drawing has some corruption on it, run the AUDIT command as many times is need it until it returns all 0
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Message 4 of 10
Hi yes I run audit very often and it returns with 0
Message 5 of 10
I'm using Civil 3D 2016
Message 6 of 10
tmachado
Please type ABOUT in the command line and load a pic of what you see
Tatiana Machado
Message 7 of 10
Todd_Rogers
Sounds like you might have some overlapping segments on the feature lines. Type in FINDSITEOVERLAPS and see if it finds any. If it does, the command line will then prompt you to run the REMOVEDUPFEATURELINES. This will usually fix the corruption.
Todd Rogers
Civil Administration
Message 8 of 10
fcernst
Yes, this is a defect in both 2017 and unfortunately continues in 2018..The case number is below for reference.
Poor product management regarding quality control continues.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 9 of 10
Thanks but no I didn't get a Removedupfeaturelines prompt
Message 10 of 10
Todd_Rogers
Did you run the FINDSITEOVERLAPS on all your sites? If so, did it state that you had duplicate feature lines? You might have to hit the F2 key to show more text. If it does state this, it will also say to run the command REMOVEDUPFEATURELINES.
Todd Rogers
