Civil 3D points compared to feature line
rio_porter
Message 1 of 8
rio_porter
I have a query.....
We have a 3D design given and i have completed a small survey along the extents of a feature line. These have been marked out, however I am wanting to create a comparison that can be sent out over email.
Is there a way i can compare the heights of the feature line to the heights of the points i have surveyed?
Thanks in advance 🙂
Replies (7)
Message 2 of 8
AllenJessup
The way I might do that (never actually done it) is to create two Surfaces. One from the Featureliness and one from the points. Use those two Surface to create a Volume Surface
Then set points on top of your original points and have them take their elevation from the Volume Surface. Export those points to a TXT or CSV file and you'll have a file with the differences shown as the elevation.
Allen Jessup
CAD Manager - Designer
Message 3 of 8
rio_porter
This appears to of worked but it has only provided the TXT/CSV file. With the linear aspect of my job (Highways) i dont have reference for the points used so to a manager or QS it will be useless. Is there a way to show this on a points labels maybe?
Message 4 of 8
AllenJessup
There seem to be a couple of methods mentioned in THIS thread.
There is a Dynamo file posted HERE that's supposed to add the Sta. - Off. to the points.
Allen Jessup
Message 5 of 8
tcorey
Use Project Explorer to compare a Point Group to a Feature Line.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 8
nkiakas
Hi @tcorey
This sounds interested (by using the project explorer).
Can you give more details?
Thanks you
Message 7 of 8
Jeew-m
If you have one feature line (Or a few),
Create points on your feature line. (Create points --> Misc --> Automatic)
Export the points to csv
Compare with what you already have.
I assume coordinates are same in both cases.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 8 of 8
brian.strandberg
I don't believe Project Explorer can compare to a point group - if it can I would love to know how, maybe with Object Sets?  When I have a feature line selected in PE Compare to: doesn't include point groups.
You can create a surface out of your points and easily compare the feature line to that.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
