Hi, I am having a problem plotting my civil 3D plans. The labels and annotations keeps on scaling up.
I have tried everything from annotation scale to standard scale.
See screenshot below:
Joe Bouza
Where can I examine the style definition and be sure the text height is set to a potted height, not a model space height?
thank you.
The drawing in which the annotation resides
Joe Bouza
I've tried all the solution,
But it keeps on coming back on a larger scale.
I've tried all the following:
-Manage text style
-annotative, tried on and off
-match the viewport scale and model scale
I just exploded all of my labels so that it can match the cad sheet layout scale.
I hope Autodesk could provide a solution for this.
There could be a couple things going on here, Depending on how you started your drawing template this could be an metric - imperial problem. If you are using Imperial and label styles are set to metric or vice versa that could be causing you the grief. if you are wanting imperial text height like 5/64" but the style is set to a metric height 2.54 that could be why your text is coming in so large. have a look and let me know,
Josh
Thanks for all of your help.
unfortunately, still doesn't work.
I just exploded all the labels to make it readable and scaled in layout views.
