Civil 3d Landxml
Civil 3d Landxml
Civil 3d Landxml
Hey guys!
Could someone tell me why the excavator operator couldn't see my TIN surface in the machine? what I did was simply a model of the whole terrain - ditches, roads, krusings etc.
First attempt we gave only the LandXML with the surface,
Second attempt we gave the same surfaces, but also added feature lines...
What is the method step by step in exporting my model to the excavator? Could someone give me a simple example step by step?
Michal Kowalski
Pointdump
Michal,
Welcome to the Forum.
Machine Control is usually proprietary. If it's Trimble Machine Control, you'll need two files, SVD and SVL, which stands for Site Vision Design and Site Vision Linework. The SVD file is converted from the Trimble TTM (Surface) and the SVL is a converted DXF file. Trimble Business Center HCE, even the free edition, will convert a Civil 3D Surface (DTM) and LInework (DXF) to the necessary format.
I would imagine that Topcon works similarly, but I don't have any experience with Topcon.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
andrewpuller3811
Topcon uses a proprietry tp3 file which can be created using the free Topcon 3D-Office programme which can import various formats for linework, control points, points, surfaces and alignments
3D-Office can import dwg (I would think as triangle faces), LandXML and others for surfaces.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
joantopo
with Trimble or Leica you can convert the TIN surface to 3Dface  in a DXF file.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
