Trying to update from civil 3D 2016 to civil 3D 2017 and get the following error message:
Error 1321. The installer has insufficient privileges to modify this file: C:\programdata\microsoft\windows\startmenu\programs\autodesk\uninstalltool.ink.
I am logged in as the administrator and the computer has all the windows updates installed.
Solved by Jeff_M. Go to Solution.
Thanks Jeff. The install worked however I not get the following error when I open civil 3D. Any help is appreciated.
unhandled e06d7363h Exception at fdd3a06dh
I'm getting this error trying to install 2020 on a Win10 machine, except that the folder is C:\Windows\Fonts. Apparently this folder is locked down in Windows 10.
