After export of civil 3d to Auto CAD drawing texts and profile bands has been exaggerated and even in civil 3d layout same error appearing.
Please give solution how to fix it.
Solved by Dexterel. Go to Solution.
Hi @Anonymous, Try installing the 2019 Civil Object Enablers on the computer using LT 2019.
Also how are doing the export. Try using EXPORTTOAUTOCAD command.
Thank you very much.
Solution suggested by you almost worked. PFA screenshot.
LT scale was 1 now its 0.0001.
How to reduse scale still less, because still there is an exaggeration of bands.
