We are using C3D 2014 on W7-64bit Pro 8gb RAM AMD FirePro 4900
Civil 3D crashes after using Copy Paste command alot. See attached pdf.
It also performs 'scanning the drawing' with each Copy Paste.
I've run PURGE FILTERS AUDIT but it still happens.
Any Ideas on a fix would be really welcome.
thanks
Steve Ennis
Solved by kepano530. Go to Solution.
First check if any updates are need for autocad, graphics card (make sure your software version is compatible to your version of Autocad) or windows, and even if there is no update I save and restart the computer, next go to task manager and see if there are other programs that could be messing up autocad, I normally try to turn everything off anything that can be off. If I am being very thorough I do the following.:
AutoCad Changes:
Note: INSIDE AUTOCAD
Computer Changes:
WARNING: this will change the look of your computer, but make it faster
If none of these solutions work:
Hope this helps.
Just read the error message, looks like you will need to perform a clean uninstall and reinstallation of the program.
According to : https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
does the computer crash a lot from copy paste or does it crash from a lot of copy paste?
Joe Bouza
I found the solution after hours of digging around online. Apparently there is a dbx file that is out of date in versions 2014-2017. The solution can be found here: http://civil3detcetera.blogspot.com/2016/08/civil-3d-2014-civil-3d-2017-performace.html
I hope this saves anyone else who runs into this issue the time we lost without it. Happy CADing
