Civil 3D Forum
Civil 3d corridor and Assembly
9 REPLIES 9
Message 1 of 10
746 Views, 9 Replies
Hello ALL,
I m trying to build a football field
I have an existing surf.
alignment
Profile has EG and FG
I build a corridor that has "basic lane" assembly to represent the field.
Please help me on the next step of how I can have the assembly connect to Existing Surf
See attached
9 REPLIES 9
Message 2 of 10
nilesh33
I will suggest you to use 'Generic subassemblies' for this corridor.
These subassemblies have more options to target surface, elevation target, slope & widths etc.
For your case use 'Link slope to surface' instead of Lane width.
"Please accept as solution if is helpful"
Message 3 of 10
in reply to: nilesh33
I have add the subassembly "linkslopetosurface" into the corridor assembly, how do you make it show in the cross sections?
Message 4 of 10
bforr
wouldn't you need a humpback or turtle shell shape?
Message 5 of 10
in reply to: bforr
what do you mean?
Message 6 of 10
bforr
I believe a football field shape should be rounded and your image shows straight lines with a p.i. in the middle.
Message 7 of 10
in reply to: bforr
Its a youth soccer/football field, so the crown in the center would b just fine.
I still can NOT show the ADDITONAL assembly (side slope) onto the cross sections . Any idea ? I really need help
Message 8 of 10
bforr
I would think it would update automatically.  Unless you have to Sample More Sources to add FG.  If you turn on tin or elevations on  your corridor surface, does it show on the additional part?
Message 9 of 10
in reply to: bforr
I would think so too, but id did not
- How do you turn on tin ore elevation on the corridor surface?
when i click on Assemblies in Prospector tab it said i have "Unassign Subassemblies" no opetion to "ASSIGN" it
Message 10 of 10
bforr
If you created a surface for your corridor, determine the surface style and under the display tab, turn on what you need.  I am not sure about the unassigned subassembly.  Sorry.  Search for Subassemblies from Polyline in the Forum here.  I just saw something that may help you.
Here it is.  http://forums.autodesk.com/t5/autocad-civil-3d-general/subassemblies-from-polyline/td-p/3252340
Rail Community
