Civil 3D Command line
mnortonBH37X
Message 1 of 8
mnortonBH37X
When my program updates, my command line settings are reset to whatever the default of the day happens to be. I am not a complex man. I prefer my command line docked below my icons at the top of my screen, about 4 inches long, AND STILL BE ABLE TO DISPLAY MY LIST DIALOG BOX. Can someone please help me before I bludgeon an innocent bystander with my T-square?
Norton
Replies (7)
Message 2 of 8
AllenJessup
Are you saving your Workspace and making it your default Workspace?
Allen Jessup
CAD Manager - Designer
Message 3 of 8
mnortonBH37X
Hi, Allen. Yes, I am.
Message 4 of 8
brian.strandberg
Try changing the LOCKUI system variable.  If you dock your command line you can set LOCKUI to 1, which will lock all docked panels.
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 8
mnortonBH37X
Thanks, Brian. I'll try that and see what happens on the next update. My personal preference is a smaller, floating command line and F2 to display as a separate window. It was great yesterday. Today... not so much. I've wasted too much time on it this morning already.
Message 6 of 8
brian.strandberg
Its highly annoying, I have looked into writing code to force the command line to a specific location / orientation but have not been successful.
Message 7 of 8
mnortonBH37X
No. I didn't get the answer I needed. I respect the members of our user group. I've been a member a long time. Just once I'd like someone from Autodesk to step in an offer a definitive solution to a problem that they created rather than our group having to spend production time hauling up just one more anchor.
Message 8 of 8
chriscowgill7373
If you want a fix to a bug, then posting in the forums isnt going to get that for you.  I would suggest running through the support system.  I know that I see people who have issues with their command line staying put all the time.  And I've tried to help troubleshoot with the based on the settings I've used always to no avail.  I'm probably jinxing myself, but the only time I've ever not had my command line stay where I put it is when it is free floating.  Which is why I dont free float it.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
