Civil 3D - Breakline Vertices
cturlington
cturlington
I am using Civil 3D 2017.
I work a lot with break lines and feature lines.  I typically end up weeding most of the vertices but would like to add my own at a specified interval such as 20-ft or 100-ft between vertices.  I thought there was a command for adding vertices at a specified interval but cannot find it.  Does anyone how to add repeating vertices in a polyline or feature line ?
user181
Select the feature line and on the ribbon in the edit geometry panel select Insert PI. Then on the command line you have the choice of Distance or Increment. Type I and enter and then enter the increment.
