Civil 3D Forum
Civil 3D bandsets section data
9 REPLIES 9
Message 1 of 10
662 Views, 9 Replies
Hi forum
I'm trying to set up a bandset in my section vieuw.
The problem is that the bandset is showing to much data.
I want to show the data on the big gradebreaks
Weeding is not a solution, but by doing so i delete some of the points that i wand to show.
by fine tuning the weeding to a section of my profile it messesup another part of the profile
i'm using survey data and not a desing made in corridors etc.
Question 1:
Is there a way to controle the locations of the data wich is shown in the bandset?
Question 2:
Is there a way to use the same locations of the data wich is shown in the bandset for labeling with this techniqe (https://www.youtube.com/watch?v=ECIFoHop3dM)?
i hope you can teach me how to master this problem to a solution
Greetz,
Levi
9 REPLIES 9
Message 2 of 10
Jay_B
I'm not sure how to achieve what you want using Data Bands, hopefully someone here has a trick.
One way to do this is use a Section View Projection Style with the _AeccProjectObjectsToMultiSect command.
Feature Lines or 3d polylines could be drawn along the 'big gradebreaks" in plan view and those lines would be projected onto the surface in section views using an Elevation projection style.
You don't mention which version your using but if you click the "Help" tab > Tutorials > Sections Tutorials > Adding data to a section view > Projecting an Object onto a Section View.
The Section-Project-Objects.dwg tutorial drawing includes a Projection Style called "Offset and Elevation"
Settings tab of toolspace > Section view > Label Styles > Projection > Offset and Elevation.
When projecting the lines choose the appropriate surface name for the "Elevation Option" in project objects to section view dialog.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
autoMick
I did these screencasts for different problem - so they don't exactly address your issue, but you may find bits useful.
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 4 of 10
autoMick
Message 5 of 10
autoMick
Message 6 of 10
autoMick
Message 7 of 10
Joe-Bouza
You want to weed by grade break. You can write an expression in the label style to make the text height= 0. sorry im not at a work station but I invision something like this
if {the grade in - the grade out < (n),0,0.08*12}
Joe Bouza
Message 8 of 10
in reply to: Joe-Bouza
Thanks all,
Sorry for the late response!
i will try out the methodes a.s.p.
you will hear from me if the solustion is found!
greetz
Message 9 of 10
Anyone, who knows another possebility?
Message 10 of 10
Dexterel
Use a profile label and add it manually.
- make an empty band (no band labels)
- manually add profile labels to fill this band
More work but you will obtain your desired results.
Rail Community
