Dear Civil 3D Community,
We'd like to inform you of an important update regarding Civil 3D 2024.2.
After its initial release, our team discovered a critical issue, leading us to temporarily remove Civil 3D 2024.2 from availability. We are actively working to address this issue and plan to reintroduce the update as soon as it's resolved.
We appreciate your patience and will keep you updated on our progress. Thank you for your continued support.
Solved by TimYarris. Go to Solution.
Hi everyone,
As a few of you have noticed, the Civil 3D 2024.2 Update is available again on accounts.autodesk.com. This is the new build that I mentioned earlier in this thread. If you installed the previous build, you will be able to install the new build without the need to uninstall the previous build.
Thank you all very much for your patience as we sorted this out.
The release notes were much easier to read. Please pass on thanks to your team.
This update has been bad news for me since installing.. have to do a full reinstall now.. can't get past this message now:
Thank you for the update. We are looking forward to seeing improvements in the grading optimization feature.
Greetings from AXA Engineers - trusted partner for US companies seeking civil engineering design and CAD services
