CIVIL 3D 2021 PROJECT EXPLORER
EdwinG_HMV
Message 1 of 10
EdwinG_HMV
Hi
I cant find the download link for Project Explorer civil 3D 2021
only appear instal for civl 2022 and 2023, instead for 2021 appear download, but it dosen't works
I have acces to Architecture, Eingeeniering and contruction suite
Replies (9)
Message 2 of 10
brian.strandberg
Check your Autodesk account or desktop app.  I can see it here:pe-2021.png
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 10
lim.wendy
Hi @EdwinG_HMV,
Welcome to the forum and thanks for posting. As mentioned by @brian.strandberg, Project Explorer requires a separate install and can be downloaded from your Autodesk Account. Since you have an AEC collection, you should be able to download them. See the steps below:
  1. Navigate to your Autodesk Account.
  2. Make sure an administrator has assigned the product to the desired users, so the download can be accessed. For more information, refer to: Account Management - Assign users to products
  3. Find the installer for Civil 3D - Project Explorer.
    Note: although the Version listed on the account page only states 2021, the installer works for both 2020 and 2021 versions.
  4. Download and install the application.
  5. Open Civil 3D.
  6. From the ribbon, go to Add-ins section.
  7. Launch Project Explorer.
    • In versions 2020 and 2021, the icon is located under the Add-ins tab:
    • In version 2022, the icon is located under the Home tab:
I hope the above helps.
Remember to mark your post as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 4 of 10
EdwinG_HMV
Hi, i tried the solution, but as i mentioned on my post the download link doesn't work
The navigation on the autodesk account has changed, so the download link is not anymore like the images that you present.
if some one has a solution i will aprecciat that
sincerly
EG
Message 5 of 10
brian.strandberg
Are you an administrator on the Autodesk account?  I don't know how else I can help, you may want to contact your reseller and see if they can help.  I would also try a different browser to navigate to the autodesk account.  I occasionally have issues with one so I try another.
I with they had these in the general product add-ons page.  https://knowledge.autodesk.com/support/civil-3d/downloads?release=2021
Message 6 of 10
pendean
Community Legend
Community Legend
@EdwinG_HMV it could be one of these issues
Read more about how to solve the issue https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Where...
Message 7 of 10
brian.strandberg
You can check the second one by going to the Windows Add/Remove programs and search for project explorer.
Message 8 of 10
lim.wendy
If you have access to AEC collection, you should see this:
You can type it in the search box as well.
Wendy Lim
Rails Summit
Message 9 of 10
wesley
As the original post stated, the download button for 2021 P.E. doesn't work.  Can someone help, please?
Message 10 of 10
EdwinG_HMV
luckily i had the installer on another computer so that's the only solution i found
