I'm getting a major delay in either creating or editing Mtext.
About a minute until I get the cursor to pop up in editor.
... All support paths are the same as in C3D 2018.
... Tried both Hardware Acceleration on and off
... tried both .shx and ttf fonts
... tried both custom template and default template
I have all current 2020 updates installed.
Any ideas???
@CADvisers - this may be a dumb question but have you checked to ensure your OS is up to date or your graphic cards? Whenever a command starts acting up on me, it's usually an update that needs applied.
Did you recently install any other software on your machine that could potentially conflict?
@Jeff_M WIn10 solutions to try https://www.thewindowsclub.com/memory-leaks-in-windows
or
https://windowsreport.com/memory-leak-windows-10/
Is this a corporate PC? If yes, do you have apps like Trustedinstaller running? Turning them off (if allowed) might help.
Other things to try in C3D itself:
So you'd think I'd be on Win 10, and probably should be.
But still on 7 Professional.
It's just odd the Mtext is instant in 2018, and then has a minute lag in 2020.
This is having them both running side by side using same template and settings.
It seems like it's graphics card related as with most issues in 2020.
I installed it on a similar computer that's fairly equal in processor speed and ram. But it has a slightly better graphics card. With that computer there's still lag but only a few seconds.
