@cyberflow ,
There is a known issue with SuperElevation with AOR in C3D 2019 and 2020, when using custom PKT files. But the results of that issue is not a fatal error, the Super Elevation, simply won't work.
In regards to trying to recreate the crash, I did try to make it crash, the intended workflow is exactly as I described, being that the Subassembly needs to be opened, updated, and saved, in the newer version of Subassembly Composer in order to be used in the newer version of Civil 3D. This process is to allow the program dependencies to upgrade the subassemblies with the their specific frameworks like dot NET.
But if, in a separate issue, after getting the subassembly to load without a crash, there is an Super Elevation with an AOR that is not rotating correctly? Is that another issue you might be experiencing separate from the fatal error?
Copper Chadwick
Designated Support Specialist
