Civil 3D 2018 Shared Reference Point
brent.moses
brent.moses
has the Shared reference Point Tool been Moved or no longer supported?
I have all the updates installed for 2018 to date, if it has been removed is there a new workflow to support geolocation between Revit and Civ?
Mike.M.Carlson
Hi-
I believe the Shared Reference Point feature is part of the 2018 Productivity Tools.  You have to download and install that separately.  Go to you www.accounts.autodesk.com and download under the Product Enhancements section.
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
BushW
Hello @brent.moses
I'm just checking in again to see if you need more help with this. Did the reply of @Mike.M.Carlson provided yesterday work for you? If so, please select the ‘Accept as Solution’ button if the post solves your issue or answers your question so, other Community members may benefit and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
sbutler502
Hmm. We’re having trouble finding that site. We can’t connect to the server at www.accounts.autodesk.com. If that address is correct, here are three other things you can try: Try again later. Check your network connection. If you are connected but behind a firewall, check that Firefox has permission to access the Web.
