Civil 3D 2016 and 2018 - Windows Server 2016 Install
jameshickey
jameshickey
I am looking for any ideas on installing and running Civil 3D 2018 and 2016 on Windows Server.
Yes, I read the system requirements and no Server is not listed. However... does anyone have any cases where this has worked for them?
jameshickey
Just an update. I was able to get Civil 2018 to install on Windows Server 2016 Standard.
I was receiving and error on the 2008 C++ installation in the logs so I manually installed the 64 and x86 versions. I also had to rename the folder
C:\ProgramData\Microsoft\Crypto\RSA\S-1-5-18  to S-1-5_BAK in order for the C++ versions to install based on this article:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-Failure-Error-99...
James
I tried to install civil 3D 2018, but I always get an error message at the middle of the installation (no server connection).
Is there a simple way of installation civil 3D 2018?
Need help on this
Would like to help but need more info please.
What operating system?
What type of installation? Network deployment? Download? Local?
Question:
Currently on 2016 Civil 3d License, Windows 10, Window server 2012 R2.  I.T. would like to upgrade to Window Server 2016 have you had any luck?
James
Would 2016 3D work as well
Kelly
jameshickey
Hi, Yes we were successful in installing Civil  3D 2018 on Server 2016. I had some troubles initially with some microsoft C++ redistributables and .NET but I was able to get it installed and running.
