Civil 3D 2015 problem changing coordinate system when adding DEM to surface...
MikeKitchen5860
Message 1 of 10
MikeKitchen5860
I downloaded a USGS GDEM which I was hoping to make into a surface. However, the DEM is in Lat Long and my drawing is UTM Zone 11N NAD 83 (metres). Anyway, following the help file, I made a grid surface, added the DEM's TIFF file to the definition. However, under the DEM's properties I can't change the DEM's CS Code to match the file information. As such, my DEM surface is not converted to my drawing's coordinate system. Is this a bug in Civil 3D or am I just doing something wrong?
Mike Kitchen
Replies (9)
Message 2 of 10
AlmasSuljevic
Autodesk Support
Autodesk Support
Please see these two posts:
http://beingcivil.typepad.com/my_weblog/2011/02/import-metric-dem-file-into-imperial-drawing.html
http://beingcivil.typepad.com/my_weblog/2010/11/correctly-locating-dem-data.html
See if the procedure where you create TIN surface works for you.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 10
MikeKitchen5860
Hi Almas,
Thanks for responding. I followed these directions. However, where I try to select the coordinate system (CS) for the DEM, there is no "..." button to select. I'd just done a clean install of Infrastructure works on this machine last month and I've been keeping up with updates, so I hope this isn't a bad install.
Message 4 of 10
almas.suljevic
Can you click in the CS Code field and see if the [...] will show up. See this for reference:
Message 5 of 10
MikeKitchen5860
Hi Almas,
No, that's the problem - the ellipsis [...] button in the CS field does not appear and I cannot select a coordinate system - as such, my DEM surface does not get translated to the drawing's coordinate system (which makes things pretty useless - given I don't do design or mapping work in Lat/Long). Has this happened to anyone else running Civil 3D 2015 SP2?
Mike Kitchen
Message 6 of 10
AlmasSuljevic
Autodesk Support
Autodesk Support
Hi Mike,
Can you check this link to see if it helps with missing buttons: http://beingcivil.typepad.com/my_weblog/2009/10/browse-button-in-import-survey-data-dialog.html
Also see this image and make sure that your Value column is not sized where you cann't see it.
Other than this you may be having some issues with your install.
Almas Suljevic
Autodesk, Inc.
Message 7 of 10
MikeKitchen5860
Hi Almas,
It was as simple as moving changing the width of the "value" column. Embarrassing.
Thanks for your help.
Mike Kitchen
Message 8 of 10
I have the same problem but in my case extending the value column didn't help. The three dots button appear when working with a TIN surface but not with a Grid surface. I did uninstall and reinstalled but I have yet to do a clean uninstall since it takes a lot longer. Any insights?
Message 9 of 10
Adjusting the Value box is also not working for me.  My surface is great but in the wrong spot.  Help please.
Message 10 of 10
I ended up starting over.  Upon the adding DEM data I resized the CS box and that gave me the ability to select the CS.  It doesn't appear that I can change the CS code for the dem file data once it is in the surface, but since it is a fixed for the dem data it worked fine.
