Cicil 3d 2016 Arrow Head Style Bug
Message 1 of 11
I have a problem with Civil 3D 2016 (French Version). My problem is when I changed the ARROW HEAD STYLE it doesn't work. I installed all the services packs.
Thank You,
Phil,
Replies (10)
Message 2 of 11
Pointdump
Philippe,
What do you mean, "doesn't work"? Can you elaborate, perhaps post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 11
As you see, it didn't take the arrow head style that I chose (see image below)
Message 4 of 11
Pointdump
Philippe,
If you change the Arrow Head Size to 0.00mm, will that give you what you want?
What happens if you change Display to "As Composed"? Still no?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
Yes it works if I don't want any Arrow, but if I want to another type of arrow, it doesn't  work. (see below)
Message 6 of 11
Pointdump
Philippe,
OK, sorry, I misunderstood you. So no matter which Arrow Head Style you choose, you get the filled arrow, right? Is this a problem with every label style, points, general note, structure, etc., or just one kind of label style? Is this a problem with all drawings or just one? If you open a new, stock template is it still a problem?
Can you post your drawing for testing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 11
Pointdump
Philippe,
The Arrowheads are blocks, so check to see if those blocks are in your drawing. Maybe it's using the Closed Filled because that's the only Arrowhead Block available.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 11
 See in attachment a test that I did
Message 9 of 11
Pointdump
Philippe,
I was able to change the Dragged State Arrowhead with no problem:
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 11
I know this is a silly question but, are you hitting the apply button when exiting all of the edit panels? I have gotten into a rush some times and missed one when exiting the editor. I was also able to change the arrow type to three different types
Message 11 of 11
I spoke with CAD specialist in my company and they told me that it seem to be a problem since 2014 (French Version)
