have you refreshed the project view? Sometimes it needs to be forced to
refresh. In prospector, select the project in question, right click and
choose Refresh.
If that isn't it, please verify that you checked it into the right project.
When you first run the Add to project wizard, it prompts you for the project
you wish to check it into - it defaults to the "Active" project, and if you
want it to go to a different one, but miss this step, you could have added
it to the wrong project by mistake (I've done it a couple of times myself).
Hope that helps.
AG
wrote in message news:5257316@discussion.autodesk.com...
I know this wounds like a dumb question, but I am unable to get my surface
to show up in the vault!
I have my surface in x-topo.dwg. I added it to my project (yes I checked the
boxes allowing the surface to come w/) Then I check my project and there is
nothing there for surface! I have been able to do this successfully (in a
different project) before..what could I be doing wrong here? Thanks!
-Rebecca
Autodesk Civil 3D 2007
SP1A
