Hi, I have worked out a custom sub assembly for Channel using Sub Assembly Composer. But I am stuck on one step which I could not figure out how to solve. My problem is to fix the targets (horizontal offset and Elevation targets). I need to put the offset target and elevation target on the top right point (P6 on the image, or the PKT file), so that when changing offsets and/or elevation the geometry stays intact i.e just stretches sideways or up/down. Currently the horizontal offset target is P2, and Vertical Elevation target is P4 (See image and PKT file). It is needed a little tweak on the flowchart Properties to make it right. Could you guys work out the PKT file attached and post it back here. Thank you in advance.
Note: The attached zip file contains the PKT file.
