Channel Sub Assembly using Sub Assembly Composer HELP PLEASE
shashimanandhar1417
shashimanandhar1417
Hi, I have worked out a custom sub assembly for Channel using Sub Assembly Composer. But I am stuck on one step which I could not figure out how to solve. My problem is to fix the targets (horizontal offset and Elevation targets). I need to put the offset target and elevation target on the top right point (P6 on the image, or the PKT file), so that when changing offsets and/or elevation the geometry stays intact i.e just stretches sideways or up/down. Currently the horizontal offset target is P2, and Vertical Elevation target is P4 (See image and PKT file). It is needed a little tweak on the flowchart Properties to make it right. Could you guys work out the PKT file attached and post it back here. Thank you in advance.
Note: The attached zip file contains the PKT file.
hi,
i change targets so that you can control from p6, see if this works for you.
pkt in att
shashimanandhar1417
Hi  Ibaskaric
Thank you for revised Sub Assembly pkt file. It is much better now. Just need a minor change. Could you remove Link L9 and join P5 and P6 so that there is a horizontal line just above the Chamfer. You help would be much appreciated.
try in SAC add vertical target for p4, see the picture for reference....
shashimanandhar1417
Hi Ibaskaric
Thank you very much. It works. But it would be perfect if I could use the Channel Height as the vertical target. I know I can offset the Channel Height profile on longsection with the amount of Chamfer distance and use it as a vertical target profile. I would not request any further help on this matter. Thank you again for your help.
