Change structure sump depth for multiple structures
JeffPaulsen
JeffPaulsen
I have about 100 manhole structures with a 0.5' sump. I want them all to 0.0'. Is there a way to change the sump on more than one structure at a time?
The only way I have found to change the sump depth is one at a time through the structure properties.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
sjgoessling
You can create a Rule to set set sump depth to 0, then apply that rule.
Steve Goessling
JeffPaulsen
Thank you. That worked.
I modified the rule set to only include the sump rule and applied it to all the sanitary runs. It took 15 minutes but that is definitely faster than changing each structure individually.
Jeff Paulsen
