I attach a dwg file to illustrate a problem I am having with SURFACES.
Designed 2 [exploratory] surfaces for Driveway/Parking for a Residence - created a design plane
for each using a rectangular feature line [from polyline] assigned very simple slopes [2/2.5%] to drain away from House. Created surfaces for each area. I did this mainly to collect sample spot elevations in various areas around the House and garden so as to aid in the design of access roads/retaining walls and of course the more detailed design of the parking areas.
Being an old diehard I also like to have contours displayed - granted they are very few in such small areas/slopes BUT they do confirm general drainage/slopes not to mention the fact that the surface IS there
I restarted the project this morning but the contours were not displaying as I had left them on closing - I pressed rebuild and to my surprise the contours on the top most parking area [also top of page/North] displayed as shown. [Note I didn't Rebuild the lower area - it still displays as when created]
The four corners of the original Feature Line rectangle were originally set at 8.4 and then graded right to left at 2% in short the four corners were in and around 8.4/8.3 - now the contours show a +/- 3-4 metre fall across the surface and some spots in FeatureLine Editor show below 4M!!
What has happened? I thought once created a Surface was 'Stable' like the coordinates of a line once drawn in Autocad.
I am still on a steep learning curve with Civil 3d but Hell it has more variables than Beelzebub himself!!!
Que Passa? I thought I had just learnt a fool proof workflow with Surfaces!!! Evidently Not!!
Solved by AllenJessup. Go to Solution.
Solved by tcorey. Go to Solution.
@christopher_c_donovan wrote:
... I thought once created a Surface was 'Stable' like the coordinates of a line once drawn in Autocad.
A surface is not a "stable" object. If it's underlying data change, the surface will update to show those changes.
I thawed and unlocked the 2 "Parking" layers and the contours show. There's only one in the bottom. So it's easy to miss.
Allen Jessup
CAD Manager - Designer
Thanks - you are absolutely right!! I need to Play with this more! Mucked about yesterday with a couple of
quick rectangles/building pads - created feature lines and surfaces for both and then broke the rules and dragged them over each other and took a good hard look at what happened.
It was educational to say the least - sometimes hacking your way through things is the right approach and others quietly taking a good look around.
I am still in Primary School with this software!! There are going to be more than a few embarrassing moments!!
Much obliged for your input.
Thanks - I have been moving too fast with my education!! Need to play with surfaces some more!!
I think what happened to the Top Parking was due to my trying to grade the House slab [with a rectangular feature line] directly adjacent to it. I had put a boundary around the Top Parking Surface and 'forgotten' that the feature line rectangle that I had used to 'design' the original surface extended beyond the Parking and over the House with the consequence the two 'design' rectangles [break lines] interacted causing the change in the Top Parking contours when I pressed Rebuild.
Thanks again for your input -I am sure there'll be some more embarrassing moments to come. Your patience is greatly appreciated
As the sages say - there are many ways to bow down and kiss the ground - and learning Civil 3D is certainly one of them!!
We've all been there. Post again when you hit the next bump.
Allen Jessup
the problem is when i was open civil 3d there is problem in creating surfaces in style bar open and also dwon area there is nothing to do and show me any options
