Center Line Coordinates as Lat Long
nglatne
Message 1 of 8
nglatne
HI,
Its Urgent, Please anybody can help me to export Center Line coordinates as Latitude and Longitude.
I got C line coordinates in Northing and Easting from the Reports Manager on the Tool space, Toolbox Tab.
Replies (7)
Message 2 of 8
AllenJessup
Set Cogo Points along the Alignment and include the Lat/Long in the export file format.
Allen Jessup
CAD Manager - Designer
Message 3 of 8
Jeew-m
There is another way to export the lat long. By default it may give deg and seconds. But with settings you may change them to decimals if needed.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 4 of 8
nglatne
Thanks for ur reply.
I couldn't get what I want. Let me elaborate on my requirements. I have a Design Center Line in my drawing (Civil 3D 2018). I want to export only C Line Point coordinates at an increment of 10m. means at station 0+000, 0+010, 0+020...….. like wise. The export format shud be like "Station, Lat, Long" a csv file (as shown below)
Station         Latitude             Longitude
0+0000        19.16Deg N         73.5deg E
Please elaborate ur reply stepwise.
Attaching
1) Drg screen shot. The red line is Center Line.
2) Export File Format as text file
Message 5 of 8
AllenJessup
I don't know of any way to create that format. That doesn't mean there isn't one. Just that I don't know it.
Allen Jessup
Message 6 of 8
AllenJessup
You're best bet might to create the cogo points having the parameter "Prompt for Descriptions" set to "Automatic - Object". Then export a point file with columns - Latitude, Longitude and Description. Then open that file in Excel of a text editor and alter it as needed.
Allen Jessup
Message 7 of 8
nglatne
Hi all,
I found the easiest way of transforming the Cogo Points ( Northing Easting) to Lat Long by using the Global Mapper as a medium.
In this exercise
1) Generate file of Center Line (or any other Points/Group) Coordinates by generating Incremental station report at required interval (which gives you report having column headings  Station, Northing and Easting). Convert this file to csv file by keeping only Northing and easting.
2) Then set the Global Mapper projection to your UTM Zone with WGS 84 as datum. then open the csv file in the Global Mapper.
3) After opening the csv file, change the projection from UTM to Geographic (Lat Long)
4) then export the file to csv format by using the File --> Export -----> Vector/Lidar Format ----> choose the format as csv.
5) That's it, you got the points converted to from N E to Lat Long.
Happy Learning
Message 8 of 8
lynn_zhang
Hello @nglatne
Glad to hear you figured out a way to fix the problem and thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
Lynn Zhang
