Cant see my corridor
ArthurADas
ArthurADas
I made a few corridors, 1 simple from an alignment and 2 of them from 2 intersections. Later, when i was messing with others part of the project i realized that the corridor were gone. They exist on prospector tab, they are visible (lamp on) and nothing is isolated. When i try to create a new corridor it doesnt show up just as the others. I'm attaching a image.
schroederC3D
Can you show a screenshot of that Parameters tab in the corridor properties?
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
ArthurADas
Sure, here it is
Have you checked that the corridor layers are on / unthawed in layer manager?
ArthurADas
Ok, this is so embarrassing, my whole corridor was just frozen... Sorry guys hahaha, but your suggestion will help someone in the future.
Yes it helped! I know I did not freeze those and don't know how it happened 🙂
