Cannot use Graphic Acceleration with Nvidia Quadro T1000
mconway
mconway
We got a batch of new Laptops for our Designers to "Work Mobile." I checked all of the specs to ensure that they will work with the AEC Collection. However, when our first user cracked it open their first drawing, there were random lines everywhere and the hatch was blown out.
I was only able to correct both issues by turning off Graphic Acceleration.
We have an Nvidia Quadro T1000 Graphics Card which specs say should be fine.
Am I or IT missing a setting somewhere?
At your service,
__________________________________________________
Mark A Conway –Director of Design Technology | Gilmore & Associates, Inc.
Autodesk Certified Instructor
AutoCAD Civil 3D Certified Professional
Autodesk Certified BIM Specialist for Roads and Highways
JRitner
Mark,
That's a bummer! Have you checked here for certified hardware/drivers for your OS & version?
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
pendean
Community Legend
Community Legend
Turn off LINESMOOTHING and LINEFADING variables and see if that helps, instead of turning off Graphics Acceleration.
you can also tone down the 2D and 3DDisplay Settings check boxes/pulldown menu section of your GRAPHICSCONFIG command pop-up before turning off hardware acceleration.
Then, you can try newer (or older roll-back drivers) for your video card to see if that allows you to undo what I suggest you do above, if you cannot find an exact driver to use from Autodesk here https://knowledge.autodesk.com/certified-graphics-hardware
HTH
jmayo-EE
I would try dean's suggestin and toggling the graphics options. If it doesn't work note that a generic windows driver from windows update sometimes can be more stable than Nvidia or ati drivers.
John Mayo
GTVic
It may be possible that the built-in GPU on the CPU is getting in the way. This possibly could be affected by which display you are using (laptop panel, VGA port, HDMI, DVI, DP, etc.). If you have dual GPUs you can try to configure which GPU is operational for AutoCAD with the NVIDIA control panel or adjust BIOS settings (e.g. to turn off the built-in GPU). Sometimes the built-in GPU operates in pass-through mode.
Unwanted-linework-appears-when-opening-drawings-in-AutoCAD-2015
