- Mute
- Permalink
- Report
I have several 3D lines that represent culvert pipes that are draw between the invert elevations of each culvert. I've been using such lines for decades now and have never had any problem selecting them. I have a routine that will locate the station at which any line crosses my pipeline alignment. If it is on a pipe layer the invert, material, and size of the pipe is recorded, drawn and labeled on my profile, otherwise an appropriate crossing label is created. A series of graphic selection windows is used so the lines must be graphically selectable for the function to work. (I won't use Civil 3D objects for my pressure pipelines because they simply don't serve the purpose so this is best for me for crossing culverts.) Today all of these 3D lines became unselectable. There are hundreds of other 2D lines that are all selectable but none of the 3D lines could be selected. These 3D lines are on several different layers each designating the material and size of the respective culvert.
I tried restarting AutoCAD - no change
I can select them by using the "previous" option after creating a selection set using (SSGET "X" '((8 . "CI????4ES##P"))) which is the wildcard pattern for all of the layers involved, sooo...
I tried wblocking them out. - no change
I tried copying them to the clipboard with a base point and pasting them into a new drawing - no change
I tried inserting the wblocked file into a new drawing - no change
I tried inserting the wblocked file into a new drawing with the explode option selected - It worked! I could select them.
I tried reinserting this new drawing into the original drawing with the explode option selected - fail - I could no longer select them.
Finally, I inserted my original drawing (explode option selected) into the new drawing in which I can select the 3D lines - That worked! I can select the 3D lines again.
Does anyone know what caused the 3D lines to become unselectable in the first place?
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
