Cannot convert autocad points to civil 3d points
pics.munmun
Message 1 of 13
pics.munmun
I am trying to create the autocad points to civil 3d points to generate a surface in civil 3d.
But i am not able to create them. (see the attached picture for reference)
Accepted solutions (3)
Replies (12)
Message 2 of 13
rl_jackson
Those points are actually blocks, with the name CROSS, question is do they contain additional information?
You can use the blocks to create a surface. Just expand the object type and select blocks
Rick Jackson
Survey CAD Technician VI
Message 3 of 13
Joe-Bouza
I would go with @rl_jackson  suggestion.
When trying to convert what does the command line say?
AHA!
the default point creation has elevation and description set to manual so you would be expected to enter this on the command line. you don't want that.
Home tab>>>create ground data panel>>points>>>point creation tools>> set elevations and description to automatic and provide a description.
Then use the command
Joe Bouza
Message 4 of 13
Joe-Bouza
Did you get a secret message? all I see is a png file
Joe Bouza
Message 5 of 13
Jeew-m
I also suggest the way by Jackson.
But you can use data extraction to export these AutoCAD data and filter the points details to a csv file and then import back to Civil 3D.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 6 of 13
rl_jackson
The png shows a properties pane, and it shows that its a block, in the misc portion.
Rick Jackson
Message 7 of 13
Udo_Huebner
As @Joe-Bouza already said you have block references, not plain AutoCAD Points.
To get Civil Points, see this thread:
https://forums.autodesk.com/t5/civil-3d-forum/convert-blocks-to-points/td-p/7373925
To get quickly a surface use Blockreferences for surface creation directly.
I prefer to export Blockreferences to an ASCII file using _DATAERXTRACTION, then use the point file later to create the surface.
Gruß Udo Hübner (CAD-Huebner)
Message 8 of 13
Joe-Bouza
@rl_jackson  good catch! I was scratching my noggin hear
Joe Bouza
Message 9 of 13
pics.munmun
When i select the points. command line shows an error that its an invalid selection set. and ask me again to select the points.
Message 10 of 13
pics.munmun
4.pngI cannot import all points from AutoCAD.
Message 11 of 13
pics.munmun
To create a surface from blocks. the command surface for me is not activated.
I am new to civil 3D
Message 12 of 13
Jeew-m
First make sure you have the correct file format of the text file.
Then when importing points close the text file if it is already open.
In the preview area it will only show 20 points. But it will import all points.
Jeewana Meegahage
Design Engineer
Message 13 of 13
Jeew-m
Please refer this video to learn about create surface from objects.
Jeewana Meegahage
Design Engineer
