Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I cannot convert the sketch road which i created and the existing designed road.but in Civil3D course tutorial they said we can right click on the sketch road and select "convert to design road". If you know some solution for this issue please let me know.
Solved by Jeew-m. Go to Solution.
Solved by wfberry. Go to Solution.
As bill says you can get a better help from infraworks forum. But in the meantime I have found that design road option is no longer there. I think you are referring to the course of Autodesk Academy.
Now the software is updated and all the design roads have converted to component roads as stated in the link below.
http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-97A0F902-9CE1-4096-A3B8-CE9EE1B2C0AA
yes you are correct ,I'm following Autodesk course which is given by Autodesk. and also your answer is very helpful for me. thank you very much.
