Hey guys, so I'm a student just learning the basics of AutoCAD and Civ3D, and anyways I was just wondering if it's possible to create a curve using 3 lines as references. There's a member of one of my school groups that's convinced that this can be done without the fillet command, and I was just wondering if this is possible.
Thanks!
Cameron Hoglan
Solved by Jowennl. Go to Solution.
Solved by tcorey. Go to Solution.
There are various ways you can define a curve but by 3 lines is not one of them. Perhaps he was thinking of by 3 points? Nonetheless here is a graphic showing the various ways you can define a curve from the Civil 3D Home ribbon in the Draw panel.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
You can make a spline that way. Maybe your friend is using "curve" to mean "shape" or "spline". In some disciplines, any linear figure is called a curve. Most Civil 3D users hear "curve" and we think circular curve or AutoCAD arc.
@Anonymous wrote:Hey guys, so I'm a student just learning the basics of AutoCAD and Civ3D, and anyways I was just wondering if it's possible to create a curve using 3 lines as references. There's a member of one of my school groups that's convinced that this can be done without the fillet command, and I was just wondering if this is possible.
Thanks!
Cameron Hoglan
Hi Cameron,
Your friend is probably referring to Circle command via Tan Tan Tan. No need for fillet and Circle is a curve as well. See attached animated gif.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
