Can't open Civil 3D 2025 DWG file in Illustrator 2024
boulder060
boulder060
I want to open a 3D-model in Illustrator that I created with Civil 3D, but it gives a unknown false code/rapport when I try to open it in Illustrator. I'm using Civil 3D 2025 version and for Illustrator the latest 2024 version. I saved as a 2004 DWG file in Civil 3D, but also tried other years. DXF won't work either. Also tried Civil 3D 2024 version, but same issue when I open it in Illustrator. Tried a file with just some basic 3D shapes in different layers and that wont even work in Illustrator. It just seems that I cant open any DWG's or DXF's from different years in Illustrator 2024!
I have attached my file that I want to open in Illustrator and also a basic shapes file I tried with!
Thanks in advance
boulder060
This is the false rapport I get btw, sorry it's in Dutch!
boulder060
It worked btw, I needed to install an older version of Illustrator!
