Can't navigate model space after using drive
connor.daviesXY4Z8
connor.daviesXY4Z8
Hi
I just used the drive command on an alignment and profile which was a nice feature, but now in model space, I am unable to pan/zoom around. If I try to move, it snaps back to a fixed position.
I have uploaded a screencast below to illustrate the issue.
Thanks.
Dexterel
check if you are not stuck in driving mode.
In driving mode your view is fix at a specific station.
Run command AeccDriveClose
First time you run the command you should get "Not in drive mode."
connor.daviesXY4Z8
I ended up fixing it, I'm not sure how though...
Also, here's the screencast that I didn't upload. Perhaps it might indicate what I was doing wrong
