Can't Move Line to Tangent of Circle
jcrow02
2,196 次查看
8 条回复
1 条消息(共 9 条)
jcrow02
I suddenly can no longer move a line segment to be tangent with a circle.  It snaps to some crazy positions.  I do not use Osnaps, rather type in tan in the command line.  Any ideas on this?
Jusitn
0 个赞
2,197 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
jmayo-EE
Does the line have the same starting Z value for the start, end and is the the same as the center of circle?
John Mayo
0 个赞
3 条消息(共 9 条)
jcrow02
yes, all z values are zero.  I have used this same technique so many times, but all of a sudden I can't.
0 个赞
4 条消息(共 9 条)
codee
I have not known what you are trying to have ever been possible in C3D.
However, you can draw a line from the center of your circle and perpendicular to your line and then move your line to the intersection of the circle and the new line drawn and it will be be tangent.
0 个赞
5 条消息(共 9 条)
不适用
I am not familiar with MOVEing a line to be tangent, either. I can draw one tangent to one or two circles. When you move it, where do you snap to on the line? I just tried it using midpoint and it went to some point on the circle, but not tangent.
0 个赞
6 条消息(共 9 条)
jcrow02
i have a line segment at a specific taper, that line has a tangent to the curb return radius that I've always just moved tangent to the radius, thus giving me the exact taper I want.  I would simply perform the move command from the endpoint of that segment and viola, it was done.  Obviously there are many other ways to perform this task, I just thought it curious that it didn't work all of a sudden.  I found a thread from a couple of years ago and they started having the same issue, but no resolution.
0 个赞
7 条消息(共 9 条)
jmayo-EE
Post a file with he exact line and circle.
It may be that tangency can't be computed from the start point.
John Mayo
0 个赞
8 条消息(共 9 条)
不适用
Try typing in plan
Then type in W for world
Then try to draw a line to a circle using the tan option.
0 个赞
9 条消息(共 9 条)
Pointdump
Hi Justin,
"...line segment at a specific taper..."
You lost me there. Can you post your drawing or at least a screen shot of the problem?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
0 个赞
