- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I hope someone will be able to help me. When I try to import from file, firstly the filter has to be turned off, even though the .csv is clearly comma delimited and in PNEZD form. But if I turn off the filter so I can select "PNEZD (comma delimited)", the preview shows up fine. However at this point the "OK" is greyed out. Nothing I have been able to do so far has change this.
I apologize if someone has answered this already, I found several similar answered questions, but all of their situations were slightly different. This issue doesn't seem to have any unique problems (that I can see), it just doesn't work.
The .csv file is not open in the background, because I know that can be an issue.
