Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Can't import point from file
Message 1 of 28
When I imported point from file the program has automatic closing can anyone help me. I need this program to do my project in university.
P.S. All of my class are encounter this problem.
Replies (27)
Message 2 of 28
Jeew-m
Best thing would be upload the dwg or point file here.
Did you try with other point files.?
If the program closes probably that may be a software issue.
You can try the data by copying it to a seperate excel and save it as csv or what ever the point file format you use.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 3 of 28
Thank for reply me
I try to use .csv and another but the program still close when i click
"ok" in import point window
and have many people in my group and other group have this problems
We use civil3d 2018 with student license
Message 4 of 28
Thank for reply me
     I try to use .csv and another but the program still close when i click "ok" in import point window
Message 5 of 28
Jeew-m
Seems like a software problem.
Try to save the file to a different format. Currently if you use csv then save it as a txt and import.
Is this file too large with millions of points.? This can also cause crashes.
Also you can reset the program to defaults and check this. But be careful if you are doing this, because you may have customized settings in your Civil 3D.
Jeewana Meegahage
Design Engineer
Message 6 of 28
I try with small file
Message 7 of 28
and then program has closed
Message 8 of 28
rl_jackson
Upload your point file. It could be a header or something that's causing the hiccup. Hard to say without looking at the file itself .
Rick Jackson
Survey CAD Technician VI
Message 9 of 28
This is my point file
Message 10 of 28
rl_jackson
Your file is a point cloud. C3D cant do cloud data in the way your asking it to. Try recap anf decimate the data by about 70% and you'll probably get somewhere.
Rick Jackson
Message 11 of 28
wfberry
I had no problem.
Bill
Message 12 of 28
Yes,I think my file isn't a problem . Now I recorded my problem let see it.
and this problem isn't having with me only. It have with my many friend that use civilcad 3d 2018,2019 student license.
Message 13 of 28
wfberry
OK, it I was supposed to see what your problem is, it flew right past me.
Bill
Message 14 of 28
ChrisRS
@wfberry, my observation: At about 40 seconds in, Civil 3D simply shuts down. Does not freeze, No error message, or shuts down. I have seen this behavior before. Usually it is a corrupt file requiring that I start over.
@Anonymous, it looks like you are starting with a new, empty drawing. Be sure it is based on a stock Civil 3D template. You may want to try a different template is one is available.
Christopher Stevens
Message 15 of 28
Thank for reply me but I have tried it. It can import just 1 times Smiley Sad
Message 16 of 28
Jeew-m
All the files imports without any problem to civil 3D 2019. Mostly the installation may have a problem if everyone gets this. As I said before I would suggest few options.
  1. Use separate file format instead of txt such as csv.
  2. Reset your software (be careful if you have custom settings)
  3. Apply the updates/hot fixes to your civil 3D version. Both 20118 and 2019 has product updates.
  4. Instead using same template try to use another one and check if fails with that too. If the template causes problems you can AUDIT/Recover the template to fix problems.
Jeewana Meegahage
Design Engineer
Message 17 of 28
You should be using PENZD space delimited file format. The preview on the bottom should be correct or it won't import correctly.
Message 18 of 28
THIS IS MY FILE
Message 19 of 28
AllenJessup
That's TAB delimited. Change the Tabs to spaces and import as a PNEZD (space delimited) file
Allen Jessup
CAD Manager - Designer
Message 20 of 28
just change the Tabs with only space once?
