Message 1 of 44
Hi all,
i have a survey with existing grade shots but they are just single line text objects. I need to make them into the correct points with the correct z value. I then need to add proposed grades with correct z values. the ultimate goal is to try and create a surface showing existing and proposed so that i can figure out cut/fill calculations. File attached for reference.
I've tried the MOVE TEXT TO ELEVATION feature with no luck. is this possible?
using C3D 2016
