Can't get correct Z value for points
cadman33619
Message 1 of 44
cadman33619
Hi all,
i have a survey with existing grade shots but they are just single line text objects. I need to make them into the correct points with the correct z value. I then need to add proposed grades with correct z values. the ultimate goal is to try and create a surface showing existing and proposed so that i can figure out cut/fill calculations. File attached for reference.
I've tried the MOVE TEXT TO ELEVATION feature with no luck. is this possible?
using C3D 2016
Replies (43)
Message 2 of 44
TerryDotson
Use the FIND command to replace "x=" (no quotes) with nothing and again with "'" (foot mark).  Then the MOVETEXTTOELEVATION tool will work.  Keep in mind the quality of this surface is compromised.
Message 3 of 44
Ranjit_Singh
There maybe some option in Civil3D to do this. Here is a LISP.
;;Ranjit Singh
;;06/16/17
(defun c:somefunc  (/ el etdata)
 (mapcar '(lambda (x)
           (setq el (read (substr (cdr (assoc 1 (setq etdata (entget x)))) 3)))
           (entmod
            (subst (cons 10 (reverse (cons el (cdr (reverse (cdr (assoc 10 etdata))))))) (assoc 10 etdata) etdata)))
         (mapcar 'cadr (ssnamex (ssget "_x" '((0 . "text") (1 . "x=*"))))))
 (princ))
Message 4 of 44
cadman33619
Thanks Terry. that did the trick.
also gonna try the lisp from Ranjit... much appreciated.
now that the text is at the correct elev, can i create points for a surface (since i removed the x for each)?
my apologies, I'm a little new to surfaces
Message 5 of 44
Ranjit_Singh
My LISP will not work if you edited the text in anyway. I had made the LISP to be used without any changes to the text. Anyways, once you get the text elevated to correct elevations, create a surface from toolspace and add drawing objectsSurface_from_drawing_objects.png
Message 6 of 44
AllenJessup
I think you have one more problem. From examining shots on hard objects it looks like the point position is supposed to be the intersection of the X rather than the insertion point of the text. So that would offset the points by about half a foot.
If you can come op with a standard vector for the shift of all the points. You can copy the original text, Eliminate the X= and foot mark (') in the copied text then move the text along that vector and use move text to elevation.
Allen Jessup
CAD Manager - Designer
Message 7 of 44
cadman33619
not sure what i'm doing wrong here... i was able to create a surface and i added the drawing objects.... now i'm trying to follow steps to create a wireframe surface but its not working out for me. Is there a good tutorial that will show me how to create a surface from these existing grades, and allow me to add proposed grades?
Message 8 of 44
cadman33619
thanks Allen... i did notice that and saw that they would be off a little. I've been trying to compensate for it but so far i have not. once i figure out how to make a surface from this, i'll explore how to fix that issue.
Message 9 of 44
AllenJessup
You could try THIS. Which are the existing grades and which are the proposed?
Allen Jessup
Message 10 of 44
cadman33619
the existing grades are the ones shown... i have not yet added the proposed grades. i have the CDs completed for this job with the building, parking, etc which shows the proposed grades. I was thinking that after i get the surface with existing grades, i could somehow bring in the proposed grades and then create a surface for them. i need to be able to see both to figure out cut/fill.
thanks for the link... gonna head there now.
Message 11 of 44
AllenJessup
This is a good youtube  video. It assumes the insertion point of the text is the point. I asked about existing and proposed since the drawing also contains contours.
https://www.youtube.com/watch?v=EtMWQ55mwvM
Allen Jessup
Message 12 of 44
AllenJessup
Once you have both Surface you can create a Volume Surface which will calc the cut/fill.
Allen Jessup
Message 13 of 44
cadman33619
sorry... forgot to mention the contours...they are existing as well.
this surveyor apparently does not use traditional survey data or z values.
Message 14 of 44
cadman33619
whoa... that would be perfect.
now i have a new goal - creating a volume surface!
Message 15 of 44
Ranjit_Singh
Good point brought up by @AllenJessup. I modified the LISP to accommodate for the shift.
;;Ranjit Singh
;;06/16/17
           (entmod
            (subst (cons 1 (strcat (rtos el 2 2) "'"))
                   (assoc 1 etdata)
                   (subst (cons 10 (reverse (cons el (cdr (reverse (polar (cdr (assoc 10 etdata)) 1.58168 0.558008))))))
                          (assoc 10 etdata)
                          etdata))))
 (princ))
Message 16 of 44
Joe-Bouza
OOTB tools
DATAEXTRACTION the text selecting X,Y, value (might be contents)
Then import the xyz file
Joe Bouza
Message 17 of 44
Joe-Bouza
In excel remove the x
Joe Bouza
Message 18 of 44
cadman33619
Ranjit.Singh,
thanks so much for the Lisp.
to make sure i understand... your lisp will remove the X= and compensate for that insertion point, then move the text up the the correct elevation?
Message 19 of 44
cadman33619
actually, i'm getting an error when trying to run the lisp. Did I miss something?
Message 20 of 44
cadman33619
Not sure what i'm missing here. I've got the text at the correct elevations and i created a surface in the Prospector (i tried it 3 times. named them: EX CONDITIONS, TEST, TEST SURFACE) but my surface is not showing up. I need to see the actual surface of the grades. I've attached the file again. hopefully someone can show me what i did wrong.
Note that all other layers are frozen.
thanks so much
