Civil 3D Forum
Can't browse to open file
31 REPLIES 31
Message 1 of 32
70109 Views, 31 Replies
When I open the software and try select "open", I have to type in the name of the drawing and path on the command line, it won't allow me to browse for the drawing or show recently used drawings.  I can work around this by typing in the path and name, but it is inconvenient.  Is there a setting that I need to change?
31 REPLIES 31
Message 21 of 32
How does this switch to 0 by itself? this is not something I ever would have chosen. I'm very grateful to have found a solution. Thank you.
Message 22 of 32
Neilw_05
Often after a crash the FILEDIA variable gets set to 0.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 23 of 32
jeff_rivers
Custom commands or scripts that need to run without user input can disable echoing text to the command line while they run.  They also may set FILEDIA to 0 to prevent the dialog box from appearing; this way the script can enter the appropriate path & filename on the command line.
When the script concludes, it should set FILEDIA back to 1, but if the script is interrupted before it concludes, you're stuck with FILEDIA=0.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 24 of 32
santhoulakis
Have noticed that when a crash happens after trying to export drawing to Autocad (crashing is quite common in that case) FILEDIA is set to 0.
Message 25 of 32
great help, thanks!
Message 26 of 32
Thank you. This fixed my issue
Message 27 of 32
I can't browse MY Files window when clicking Open files.....    It just gives me a dialog box.  I entered the FILEDIA=1 and it says can't find file. I need help.
Message 28 of 32
Neilw_05
The command is FILEDIA, not FILEDIA=1. Type FILEDIA, enter, then at the prompt for a value type 1.
WIN 10 64 PRO
Message 29 of 32
MMcCall402
in reply to: Neilw_05
Also, this needs to be entered at the command line with a file already open. So, open any file, enter Filedia, set it to 1. Close the file.  Now it should operate as you'd expect with a dialog box for browsing files.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 30 of 32
thanks man that worked
Message 31 of 32
rkmcswain
Its hard to believe that in the year 2022, that the worlds leader in design software with $3.79B in revenue, still has a product that requires users to go out to a forum to find an answer about something so trivial as a missing dialog. There are so many technical ways to overcome this "issue", yet here we are still making end users wonder why it happens.
R.K. McSwain     | CADpanacea | on twitter
Message 32 of 32
Joe-Bouza
in reply to: rkmcswain
Indeed.
you point it out elegantly.  Sad reality is users have been asking this question for 30 years or more
Joe Bouza
Rail Community
