Yes you can create cogo points in civil 3d for all lines & polylines vertices.
Use Command: CREATEPTPLYLNCTRVERTAUTO for creating points on polyline vertices. its automatic method the elevations will be taken based on the vertices points.
Use Command: CREATEPTPLYLINECTRVERTMAN for creating points on poliline vertices. This method is manual and you need to assign elevation manually.
Command CREATEPTALONGLNCURVESPIR & CREATEPTONLINECURVESPIRAL these both are also very much usefull to generate automatic cogo points on poliline and line.
This can be found on Civil 3d ribbon point<<points creation tool see the attached image.
Also make sure you have done few settings before generate points because if you dont make the settings as per image its quite difficult while creating points or process takes quite long time.
Hope this resolve the issue if not feel free to share the file so that can check and resolve the issue.
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
Idea: Make feature lines from the line(s) and polyline(s). The feature lines will react to each other (when in the same site) and create nodes where they intersect. You can use the Automatic point creation option to create points from the feature lines. Delete the feature lines afterwards.
Scrap the above idea :oP
Better idea: Use the point creation option named Object/Object. (CreatepointObjectObject) This tool will create points wherever two objects intersect.
The following tool can convert intersected lines to Cogo Points or autocad points:
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=1209699820916853944&appLang=en&os=Win64
I'm afraid that doesn't work, at least not in Civil 2023.
Point or option keyword required.
; error: Function cancelled
Please specify a location for the new point: *Cancel*
