cad trying to generate
persdraftZN8X3
Message 1 of 8
persdraftZN8X3
anyone experiencing Civil 3d doing this......... just waiting to load for a long time without allowing to continue on with my drawing?
note the attachment and highlighted blue areas.
thanks,
Rick
persdraft@gmail.com
Replies (7)
Message 2 of 8
ChrisRS
This can happen when using C3D.
The file may be corrupt.
If it responds:
  1. CAD Condom
    1. Purge, all
    2. Audit, yes
    3. Repeat Audit until no changes are made.
    4. -PURGE, R, *, N.
    5. Save.
  2. Close and reopen C3D.
  3. Recover the drawing.
The smooth operation of C3D requires good file management.
Christopher Stevens
Message 3 of 8
persdraftZN8X3
thank you for your response, if the file would open all the way so I can type the
"purge" in command line, then that would be ideal, but the file is not opening all the way.
Message 4 of 8
brian.strandberg
Try doing RECOVER command.  This will check the drawing integrity.  If you suspect you could also use RECOVERALL, which will check the xrefs.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 8
neilyj666
Have you tried INSERTing into a new drawing?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 8
persdraftZN8X3
All,
I was not able to open the file fully to do any kind of copy to new drawing, nor do a purge.........
instead, I opened the drawing file I was working on in an earlier version.....weird.
I am currently working in 2024, but had to open it in 2022 which worked.
thank you all for coming to my rescue.
Message 7 of 8
neilyj666
This reply reminds me that I actually had a similar situation a few weeks when a drawing refused to open in 2024, opened with no issues in 2023, saved it and then it opened in 2024 with no problems- odd
Message 8 of 8
ChrisRS
I did not read your original post carefully enough, to see that this was happening as the file was being opened.
Christopher Stevens
