Hi Everyone,
I suddenly started to get below error while trying to use civil 3d extra subassemblies:
Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'. site:forums.autodesk.com
Anyone knows why? I use civil 3d 2022.
Solved by Hdalgic. Go to Solution.
Can you be specific as to which "extra subassemblies" you are using? Are these the subassemblies that come with the software, or have you created custom subassemblies using Subassembly Composer?
Corey thanks for the reply. These are the xtra subassemblies included in civil 3d package. Anyway I could not figure it out and full uninstall did not work either so I reset my computer clean (anyway I needed to do that as performance of my computer needed a clean slate.). All good now, I think it has something to do with .net though.
Anyway thanks all!
