C3D Subassemblies not showing on toolpalette
Message 1 of 13
Can someone help me with subassemblies?
I am creating a corridor to get the cut/fill for a road going in at a work site.  I cannot get or find any help on how to get subassemblies into the tool palette.  I have seen the previous posts about docking and making sure all the tool palette categories are selected, and they are.  I'm not sure where to go from here. It appears that my subassemblies tool palette don't even exist.
Do I need to re-install the program?  I have seen the v1 enhancements too, and not sure if that would be a fix.  (h t t p : / / u p . a u t o d e s k . c o m / 2 0 1 7 / C I V 3 D / A u t o C A D _ C i v i l _ 3 D ... )
If I'm not mistaken, I need these subassemblies to correctly link the road profile and road alignment to the existing surface topography through the corridor design tool.
Any help would be great.
thank you,
Adam
@BushW has edited your subject line for clarity: Subassemblies
Replies (12)
Message 2 of 13
I'm not sure why you need all tool palettes, but right click on Tool Palettes and select Civil Imperial Subassemblies (or whichever you actually need for the corridor).  There are too many categories for it to show them all, so it hides extras at the bottom but you can still scroll thru them.  Shouldn't require a reinstall as the basic ones come OOTB.
Message 3 of 13
I have tried that and I don't have those options when I right click the tool palettes (see attachment).  I know that I don't need all tool palettes, but I assume that the civil imperial subassemblies would be there if all palettes were selected.
Message 4 of 13
Jeew-m
Dear Friend,
Right click on desktop shortcut of civil 3d and run the program with 'Run as Administrator' mode
This might solve your issue.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 5 of 13
follow the tabs down the toolpalette and at the bottom you will see what looks like a stack of tab.  Click on that and you should get a long list of other palettes to choose from
Message 6 of 13
ACADuser
Adam,
Have a look at this> Civil tools missing from Tool Palettes in AutoCAD Civil 3D.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 7 of 13
CivilFlow
Hi
I don't think you have to reinstall.  They're there.  Try to right click on your Tool Palette tabs on the right hand side of the Tool Palette itself.  Form there, look for the options starting with "Basic" and look at the other available out-of-the-box subassembly categories (e.g., "Lanes", "Shoulders", "Rehab", etc.).  See attached screen capture.
I know there's probably an easier way to organize these into a more focused tab, but I haven't tried.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 8 of 13
ACADuser
@ACADuser wrote:
Adam,
Interestingly this link no longer works.  Attached is the info for anyone that may need it.
ACADuser
Message 9 of 13
cwr-pae
In the corridor menu (menubar set to 1) find the subassembly catalogs. From the catalog you can put the subs into a tool pallet or directly in to a drawing.
The menu option for the subassembly tool pallets just toggles the tool pallet on and off.
Message 10 of 13
BushW
Hello @Anonymous
I'm just checking in to see if you need more help with this. Did the replies of @Anonymous or @ACADuser provided work for you?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so, and I'm here to help.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 11 of 13
Hopefully he got this fixed, but in case not, it's probably time to check your Support File Search Paths under Options.
It should look something like one of these, depending on whether you use server based paths, or individual.
Message 12 of 13
CivilFlow
I have the same issue with my tool pallet. I can get the Civil Subassemblies Pallet to show though up by doing the following steps:
1. Right click on the tool pallet and click customize.
2. There you will see a two-pane dialog pop up where you will see empty palette categories on the right and all the various Civil 3D subcategories on the left.
3. Left Click and drag each subassembly subcategory on the left side (like basic, shoulders, daylights, etc) over to the right side directly under the empty Civil Subassemblies Category and click ok.
4. Try to right click on Tool Palette again and you should see Civil Subassemblies as an option now.
This method is quick and dirty. The method mentioned above to fix it at Deployment stage is best, but obviously time consuming.
I recommend following the 4 steps above because it only takes a few minutes.
Michael M. Carlson
CADD Manager
Message 13 of 13
abimanyudaniel8000
Resetting to default works for me, thanks a lot!
