C3D Offset alignment from objects
bcolonXQE5F
bcolonXQE5F
Hi!
Is possible to create a c3d offset alignment from a polyline already drawn? C3D, have a command to make this, or exist other method?
Thanks for the support!
ChrisRS
AeccCreateAlignmentEntities
Christopher Stevens
bcolonXQE5F
Thank you, very much.  I found the offset command, inside of the create alignment from objects pull down menu.
Jeew-m
Even though you create an offset alignment from an object that will not act as a real offset alignment. Usually, offset alignment is related to a parent alignment and update as parent alignment updates. In your case, that dynamic feature will not be there.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
bcolonXQE5F
ok, I understand, but even if it doesn't have the qualities of a dynamic offset, it will works so that the typical section goes through them and creates the corridor, and the cross sections?
Thank you, for your answer!
rl_jackson
If I had a Polyline I'd probably make it a Feature Line first, then you could use the feature line as a target
Rick Jackson
Survey CAD Technician VI
bcolonXQE5F
Yes, that is my case. I drew the polylines of the offsets of my alignment, directly in cad, because I had difficulties to use the c3D commands to make the transition of the widening of the proposed lane edges, to the existing edges of road.
