Hello
It depends on Why you need to combine,
combining corridors in most of the cases is a headache because you have a lot of baselines and lots of targets and one corridor sometimes is overcrowded with different baselines and targets, to have a different corridor for each of the ramps or whatever it is more convenient. there are some steps you can gather corridors in one Autocad Drawing.
1. You can prepare a complete corridor drawing in a separate Drawing file if it is possible to do it independent file, it will faster to navigate even, and regeneration will also faster for each change. At the end, you can Xref as an overlay to the other drawing. when you Xref C3D Corridor you can even make sections from that desired drawings and make profiles also. But if you want to modify you have to go to source drawing. Usually, I work like that I have different drawings for different corridors when I have complex projects if it is a roadway and at the end, I Xref them into 1 Drawing.
2. You can use data shortcuts for everything, you can promote from data shortcut your corridors or whatever. but you have to be skilled because sometimes it is a little bit tricky and maybe you might not get the desired result.
Beka TchigladzeInfrastructure Design Engineer | BIM Automation DeveloperAutodesk Developer Network (ADN) MemberAutodesk Certified Professional: Civil 3D & AutoCad
LinkedIn |
Autodesk App Store
