C3D 2020 - Data Shortcuts Source BUG Found
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In Civil 3D 2020 (2020.5.1) when creating a data shortcut to a surface, Civil 3D will path the reference (source file name) to the last saved version of the drawing. If this last save was an autosave - the source file name will be the autosave file in your autosave directory; NOT the file you're currently working in.
To test,
- We opened Civil 3D 2020.
- Set the working folder
- Saved.
- set Autosave to 1 minute.
- waited for an autosave.
- created a reference to a surface in our drawing.
- checked references, and under source file name - the reference came from the Autosave file that had just been created, not the current file we are in (that the autosave just happened in).
- removed the reference.
- turned off autosave.
- saved the drawing
- created the reference
- source file name is correct.
In short, if you use autosave and until this is fixed, I recommend Saving your file immediately before you create data references to avoid the problem.
